Tool change gcode not reading current tool properly
I'm trying to get my dual extruder printer to park properly when changing tools, so I added
G0 X{if current_extruder == 0}-40{else}435{endif} F15000
to the tool change gcode section in Prusa Slicer. If I start a print with T0, the whole print goes fine, each tool parks in the right spot during layer changes. If I start the print with T1, it tries to park T0 at 435, which just doesn't work. The gcode file has
G0 X435 F15000 T1
even though my start gcode is
G28 ;Home T0 M109 T0 S[first_layer_temperature_0] M109 T1 S[first_layer_temperature_1] M605 S0 ;Disable broken builtin tool change parking G1 Z15.0 F6000 ;Move the platform down 15mm M84 S0 ;Disable idle hold timeout ;Prime the extruder G92 E0 G1 F200 E3 G92 E0
so it should be reading T0 as the currently selected tool. It seems to be reading the tool it's going to change to as the current tool. Is there something I'm doing wrong?
Napsal : 30/09/2021 2:16 pm
Topic starter
answered:
RE: Tool change gcode not reading current tool properly
Bump. No one knows?
Napsal : 04/10/2021 12:16 pm
