Tool Change/Disabled Retraction not compensating
Lewis Chen
(@lewis-chen)
I don't know what's wrong with my settings.  I haven't changed a thing, only recently upgraded to 2.8.  Suddenly, all my tool change/disabled retractions settings start working, but they're not compensating.
I've disabled all I could find (Filament Override either set to 0 or disabled, Printer Extruders all set to 0 or disabled) but every time I print, it still retracts the filament but doesn't compensate it back.  Even when I set extra length to match the retraction amount, it doesn't push more in.
Reading through the gcode, it's retracting 30 each time a tool change happens and I don't know where that number is coming from in the settings.
My mind is boggled.
https://www.dropbox.com/scl/fi/8af6651vn17yy6ddiv9b6/Shape-Box.3mf?rlkey=l2xht8ozuyr3sg7isxs3vbn51&dl=0
Publié : 10/07/2024 8:31 am
Lewis Chen
(@lewis-chen)
RE: Tool Change/Disabled Retraction not compensating
I found the -30 retraction in the end g-code (it's so that I can switch out the filament anytime without having to heat up the hotend) but it doesn't make sense why it would be triggered during tool change.  It should only be triggered when the print job is done.
Any thoughts?
Publié : 11/07/2024 7:49 am
Lewis Chen
(@lewis-chen)
Aaand, now I see it's also in the Filament's Custom Gcode.  Don't know how that got there.  Maybe from my early days experimenting with retraction settings that never worked for me until this version upgrade.
You can close this now. 😳
Ce message a été modifié il y a 2 years 2 fois par Lewis Chen
Publié : 11/07/2024 9:37 am
1 personnes ont aimé
