Thin walls in one go (aside vase-mode)
Silvester
(@silvester)
Hello,
i am struggling to print thin walls - somewhere around 0.45 mm - in one go (like in vase-mode).
I find that the nozzle travels each way twice at the same z-value (or not at all if the wall is slightly thinner than the perimeter-setting).
Is there a way to achieve this? I can not use vase mode though for it is not a closed form.
I am using PrusaSlicer Version 2.3.0 linux x64, Prusa i3 MK3 and a 0.4mm standard nozzle.
Thank you so much!
Publié : 19/04/2021 5:38 pm
RE: Thin walls in one go (aside vase-mode)
Have you enabled 'Detect thin walls' in Print Settings?  You might need to be in Expert mode.
Publié : 20/04/2021 11:25 am
Silvester
(@silvester)
'Detect thin walls' works so far. Thank you very much!
Publié : 29/04/2021 10:14 am
