Thin walled pipe doesn't print right
I am trying to print a hollow part but the slicer is not producing the desired result. I have tried other slicer and I have the same problem. I want to use 100 % infill. Sometime the result is not hollow. Depending on the orientation the problem is different.
How could I solve this problem?
Veröffentlicht : 25/05/2021 3:07 pm
RE: Thin walled pipe doesn't print right
Can you post the 3MF file zipped?
Veröffentlicht : 25/05/2021 4:54 pm
Yes, please save your project and zip up the 3mf and attach it here. I would bet that the model has issues though, as different parts are not sliced depending on the position. The project will let us confirm that.
If you are on Windows 10 then right clicking the part in PS and using the fix through netfabb would be the first thing to try.
Veröffentlicht : 25/05/2021 7:22 pm
