Thicker layer heights for support material?
Is there a way to make the layer height for support material larger in the latest Prusaslicer release?
Seems like a good way to reduce print times. I've printed a handful of parts with multiple layer heights in the same print so the software can handle it, and you don't need that fine of a resolution for the support until the very top.
Posted : 14/11/2025 6:07 pm
RE: Thicker layer heights for support material?
For normal printing is does that anyway. Has forever. You have to specifically set it to sync the layer height with the model and its only available to sync when the contact distance is set to zero. Red/Expert level setting called Synchronize with object layers.
Posted : 15/11/2025 12:51 am
