Thickening things.
Distinctly Average
(@distinctly-average)
Thickening things.
I am trying to build this - https://www.printables.com/model/200431-nanoleaf-hex-modular
To get it to fit on the mini, I was lazy and just scaled everything to 92%. All fits together well. However, the diffusion is a little lacking.  Is there an easy way in Prusa slicer to thicken the diffuser section, or will I need to do something in a modeller package?
Napsal : 29/05/2022 6:53 pm
You can use the scale tool in slicer to change size in just one plane.  If this is not enough, then yes, you need modelling software.
Napsal : 29/05/2022 8:26 pm
Distinctly Average
RE: Thickening things.
Thanks. The scaling in one plane didn’t work too well. Just been through the learning curve of converting a mesh in fusion 360 and increased the surface from .5mm to 1mm. I guess I will know in a couple of hours whether that was enough or too much.
Napsal : 29/05/2022 10:00 pm
Distinctly Average
It worked well. 5 plates printed 4 to go. Gotta love 3D printing.
Napsal : 30/05/2022 5:23 pm
