Test Print for Spiral Vase Mode/Internal Structure Disappears
broberto
(@broberto)
I'm doing a test print for an airfoil using Prusa Slicer 2.8.1
I'm using 3dLab Print settings for spiral vase mode with an internal rib.
The STL looks fine but when I slice it the internal ribs disappear after layer 2.
Any help?
Thanks.
-- Ben
Napsal : 27/09/2024 11:55 pm
broberto
(@broberto)
RE: Test Print for Spiral Vase Mode/Internal Structure Disappears
Here's the 3MF file
Napsal : 28/09/2024 12:08 am
unfortunately no .3mf file attached.
you have to ZIP compress the file, and attach the .zip file
or the forum will ignore the file.
Napsal : 28/09/2024 5:08 am
Walter Layher
(@walter-layher)
You can't have internal features in your model with vase mode, it prints just one outer shell and nothing else.
Napsal : 28/09/2024 8:00 am
broberto
(@broberto)
Oops... my mistake.
test_airfoil_24m09d27
Thanks for your time on this.
-- b
Napsal : 28/09/2024 1:21 pm
broberto
(@broberto)
*SOLVED* RE: Test Print for Spiral Vase Mode/Internal Structure Disappears
My original cad model was a surface with solid internal ribs.
I found this link:
I built a new test piece as a solid and 'micro slots' instead of solid ribs.
The slicer doesn't show any issues.
-- b
Napsal : 03/10/2024 2:09 am
1 lidem se líbí
