Test Print for Spiral Vase Mode/Internal Structure Disappears
I'm doing a test print for an airfoil using Prusa Slicer 2.8.1
I'm using 3dLab Print settings for spiral vase mode with an internal rib.
The STL looks fine but when I slice it the internal ribs disappear after layer 2.
Any help?
Thanks.
-- Ben
RE: Test Print for Spiral Vase Mode/Internal Structure Disappears
Here's the 3MF file
unfortunately no .3mf file attached.
you have to ZIP compress the file, and attach the .zip file
or the forum will ignore the file.
You can't have internal features in your model with vase mode, it prints just one outer shell and nothing else.
Oops... my mistake.
Thanks for your time on this.
-- b
*SOLVED* RE: Test Print for Spiral Vase Mode/Internal Structure Disappears
My original cad model was a surface with solid internal ribs.
I found this link:
I built a new test piece as a solid and 'micro slots' instead of solid ribs.
The slicer doesn't show any issues.
-- b
