System presets - printer status after nozzle change
Vnze
 Vnze
(@vnze)
I own one Core One printer so I have to change nozzles if I want different options. This works great for the most part, but there's a minor annoyance that the printer's status in the model view remains linked to the original 0.4 nozzle profile.
For instance, my printer is currently equipped with a 0.6mm nozzle and configured as such on the printer itself. I can slice and print correctly. But visually, I get these views:
  • The printer is "available" in the 0.4mm nozzle system preset:
  • The printer is not visible in the 0.6mm nozzle system preset:
What setting do I need to update to get the availability of my printer with the relevant system preset for the installed/configured nozzle? Or how could I assign a printer to a preset or visa-versa? All my Google skills have have led me to is to add a physical printer, but that just creates more profiles and still has the printer showing up with the "wrong" preset.
Opublikowany : 06/01/2026 8:37 am
_KaszpiR_
(@_kaszpir_)
RE: System presets - printer status after nozzle change
you need to go to the printer menu and in Settings > Hardware > Printhead and select nozzle diameter there.
Opublikowany : 06/01/2026 1:28 pm
Vnze
 Vnze
(@vnze)
Thanks. I did change the nozzle diameter already (but remotely using the slicer). When checking the printer it's also (correctly) listed as 0.6mmm.
Opublikowany : 08/01/2026 12:19 pm
