Supports Only Generating Near Perimeters?
NateroniPizza
(@nateronipizza)
Hello all,
I've got a print I'm wanting to run that has a large overhang. The weird thing is, I can't get supports to print under the whole overhang. See pictures below, showing supports and then first bridging layer above them. These are with stock 0.2mm speed mk3 settings.
https://imgur.com/EQjZiBl
https://imgur.com/Vle6Ggz
It appears that supports are only being generated near perimeters (those two squares in the middle are around a couple of holes). Any ideas how to get them to print further back under it as well?
Thank you
This topic was modified 6 years temu by NateroniPizza
Opublikowany : 15/05/2020 8:27 pm
RE: Supports Only Generating Near Perimeters?
it's bridging to the supports!
have you tried unticking 'Don't Support under bridges?'
it's in the support material menu and requires advanced mode or better!
Opublikowany : 15/05/2020 9:07 pm
NateroniPizza
(@nateronipizza)
Posted by: @joantabb
Aha, that did it! Thank you very much.
Opublikowany : 17/05/2020 5:29 pm
