Supports not slicing correctly even though I enforced them
Flo1988
(@flo1988)
Hi everyone,
i just recently bought, assembled and now finally tested the MK3s+ and im baffeled about the print quality so far.
However i have some problems with the slicer and the supports.
I do have a pretty big part to print (cant rotate it to the other side for various reasons) and the software just wont generate supports where they are definitely needed. I attached some screenshots where you can see the overhang which needs support, the enforced support cube and the resulting supports from the slicer.
Doesnt matter if i change the support settings to "everywhere" same result.
Am i missing something?
Thanks for any help 🙂
Best Answer by JoanTabb:
@kinghelmer
I  think you left 'Don't Support Bridges' ticked
Attachment removed
Opublikowany : 22/05/2021 10:36 pm
RE: Supports not slicing correctly even though I enforced them
I need to see your settings.  Post an 3mf file that has been zipped.
Opublikowany : 22/05/2021 10:46 pm
Flo1988
(@flo1988)
@cwbullet
Hi Bullet,
heres the file saved as 3mf.
I basically only activated supports in the settings and then tried to get them to work here.
thanks for checking
Grundplatte Rechts
Opublikowany : 23/05/2021 12:13 am
@kinghelmer
Attachment removed
Opublikowany : 23/05/2021 1:34 am
1 ludzie polubili
Flo1988
(@flo1988)
Hi Joan,
thanks for the answer, that solved the problem 🙂
Happy printing everyone 👍
Opublikowany : 23/05/2021 8:15 am
@kinghelmer
That is a common error.
Opublikowany : 23/05/2021 12:40 pm
