Support layer strange resolution 0.01mm. Bug or not ?
Grégory D
(@gregory-d-2)
On a print of 0.07 height for the perimetres I've notice that my prusa mk3S clicking only on supports print.
Looking more closely at the slicing result in prusaslicer, I noticed that the slicer produce for support layer several layers of 0.01 height !
For me 0.01 height is too small even for the prusa mk3s.
Is this a slicer bug or is there a parameter to force the supports resolution to be the same height (equal of the perimeter height) ?
on the image below, between layer 120 and 121 there is 0.01 and we can see that it is not the only layer like that.
Thanks for your help
Opublikowany : 21/09/2020 7:42 pm
Area51
(@area51)
RE: Support layer strange resolution 0.01mm. Bug or not ?
Sounds like an error that should be reported on PrusaSlicer GitHub as an issue. The developers will look here.
Opublikowany : 21/09/2020 11:16 pm
Supports are completely independent of the layer height but should be limited to the min/max defined in the printer extruder settings. So it definitely sounds like a bug and should be reported.
There is a setting under print setttings to make supports match the object layer heights though in the meantime.
Opublikowany : 22/09/2020 5:11 am
Grégory D
(@gregory-d-2)
@area51 @neophyl
thanks for your replies. I will report it to the developpers.
I see the option "synchronize with object layer" in support material tab but it disabled. I've read that it can only enable for multi extruder but it's not my case :/.
Opublikowany : 22/09/2020 6:12 am
