support layer Height
detiebear
(@detiebear)
im using a 0.2mm nozzle and printing at 0.05 layer heigth. Support Material seems to have a too big layer height because they not melted and just bareley layed on top of each other and at one point they falling down. i see that i can change the layer width but not the thickness. or do i miss something?
Postato : 07/09/2019 8:21 pm
RE: support layer Height
Support heights are automatic unless you force sync with layers.
Postato : 08/09/2019 2:36 am
detiebear
(@detiebear)
Ok i see that Option is greyed out. How do i activate it?
Postato : 08/09/2019 8:33 am
Posted by: detiebear
Are you using Expert mode?
Postato : 08/09/2019 1:03 pm
Well - I can't set it now either. I seem to recall it used to work on single extruder slices.
Hmm - known issue since 2017 ?    https://github.com/prusa3d/PrusaSlicer/issues/553
Questo post è stato modificato 7 years fa da --
Postato : 08/09/2019 1:11 pm
detiebear
(@detiebear)
So no Chance to get this to Work right now
Postato : 08/09/2019 1:59 pm
Dave Avery
(@dave-avery)
reading the issue - you can set the max layer setting to maybe 0.1 instead of 0.25 under 'printer/extruder/'
Postato : 08/09/2019 2:34 pm
1 persone hanno apprezzato
