Support interface layer in different material not working correctly.
Krieger
(@krieger)
Hi all,
I was following this post to try and enable manual filament changes for support interface material.
https://forum.prusa3d.com/forum/prusaslicer/support-interface-layer-in-different-material/
However, when trying to slice using this method, this is what I end up with.
As you can see, the gcode is telling the printer to go back to Z 0.20 when printing the support interface layer. This will obviously cause a crash to occur.
Here are my settings.
I'm not sure if this is a bug, or if there is something I missed on my end.
Thank you
Opublikowany : 19/09/2023 9:59 pm
Krieger
(@krieger)
RE: Support interface layer in different material not working correctly.
Alright, well I'm dumb. I had some gcode in the filament specific gcode that was setting the Z height. My mistake.
Opublikowany : 19/09/2023 10:09 pm
