Support for post-slicing terminal commands?
markshu
(@markshu)
I can't find whether PrusaSlicer supports running terminal commands post slicing.  Simplify3D does, which allows me to automatically curl the output file via a terminal window over WiFi to my two printers which are front-ended with Repetier-Server on a Raspberry PI.  This feature really needs to be added if it doesn't already exist.
Posted : 06/03/2023 2:01 am
JimB
 JimB
(@jimb)
RE: Support for post-slicing terminal commands?
Try following the instructions at https://help.prusa3d.com/article/sending-files-to-octoprint-duet_1663 but set the host type to Repetier instead of OctoPrint.
Posted : 06/03/2023 12:45 pm
markshu
(@markshu)
Huh.  Thanks.
I read that entry, but didn't bother actually trying it because the documentation is specific to Octoprint and a search of the docs for 'Repetier' came up empty.
I would still like to see the terminal command post-slicing feature added, because while that dialog allows me to upload the file as requested, with a terminal command I'm able to upload the file to multiple printers at the same time along with being able to do general file maintenance or run custom scripts.
Posted : 06/03/2023 7:05 pm
