Support blocker settings?
SGA
 SGA
(@sga)
I am running Prusa Slicer 2.9.4. I have an item that is fairly large, and I need supports. I amtrying to get a support blocker to work. The shape is there, and the type is set to blocker, but when it slices, there are still supports there? It is a purchased .STL, so I can't easily create a break away shape to fit the supports I need. In the settings, both generate supports, and auto generated supports are checked, if I do not do it htat way, I have to paint supports everywhere else. The model is large enough I am forced to grid supports instead of organic, the base of the organic supports exceeds my print area.
I am just looking for ideas, and if I can't resolve this, I will just run the extra time and material to get it done.
Napsal : 15/03/2026 7:14 pm
