Suggestion - Favorite settings
[Resuelto] Suggestion - Favorite settings
MrHeinzzzz
(@mrheinzzzz)
Miembro
Hi, when I use Prusaslicer I noticed I often tweak the same settings per model. I have set profiles but often change things per model. Often they are on different places in the menu. I thought it would be very usefull to check different settings as favourite and they are put together in menu in model view. Than you don't have to browse through the menu's. I think it would be very time saving.
Respondido : 24/08/2024 10:29 am
RE: Suggestion - Favorite settings
you can save each page of settings under new names  within Slicer
then you can re select the preferred settoi9ngs en bloc.
Respondido : 24/08/2024 11:37 am
This is a user to user forum.  Suggestions etc need to be made on the Prusa Slicer github.  However I can tell you that this feature has been requested at least twice already (found duplicate requests)
https://github.com/prusa3d/PrusaSlicer/issues/8320
https://github.com/prusa3d/PrusaSlicer/issues/11105
Go add support to one or both of those.
Respondido : 24/08/2024 1:15 pm
MrHeinzzzz
(@mrheinzzzz)
Miembro
I'm sorry. Wasn't aware. Thanks for the links. I will support those and other suggestions (if I have any) to GitHub.
Respondido : 24/08/2024 2:22 pm
