Strange problem with supports in PS
Dik Harrison
(@dik-harrison)
I have a model that slices without issue if supports are turned off, it also slices without issues if I turn on support on the build plate only, but when I  paint supports on the only area the requires supports, I get the empty layers error.  I even tried loading PS 2.3.3 to no avail.
Postato : 18/12/2021 3:18 pm
Swiss_Cheese
(@swiss_cheese)
RE: Strange problem with supports in PS
@dik-harrison
Can you post a Zipped up .3mf project file from prusaslicer 2.3.3, If so I will take a look and see if I can help.
Regards
Swiss_Cheese
The Filament Whisperer
Postato : 18/12/2021 9:18 pm
Dik Harrison
(@dik-harrison)
Oops, I forgot to do that...
Postato : 19/12/2021 9:09 am
Majo Lukac
(@majo-lukac)
Hello Dik,
I had a look at your model and have no idea what’s going on there. I would simply redesign that area requiring the support.
Is there any specific reason for this particular design? Planning on stacking those units?
Thanks,
Majo
Postato : 19/12/2021 11:11 am
Dik Harrison
(@dik-harrison)
I have already cut that part off at a 45degree angle, so not a problem anymore.  Still think it is a bug that will be very difficult to pin down.
Postato : 19/12/2021 12:40 pm
Huh, I'm not getting any errors with 2.4-beta4:
If it was a bug looks like it's fixed now.
2.4 also allows you to use snug supports, which in this case look a bit nicer. Also, I would set the top contact Z distance to 0.25 or 0.2. 0.1 will be much harder to remove. I found that 0.25 usually comes off very easily with little scarring of the surface.
Postato : 19/12/2021 12:50 pm
Dik Harrison
(@dik-harrison)
Thanks for the solution and advice, I'll give it a try...
Postato : 19/12/2021 1:28 pm
Swiss_Cheese
(@swiss_cheese)
@dik-harrison
I added support in two areas that needed a bit and the warning went away.
(Click on the image to view the whole thing)
Use it if you like, but PS 2.4 rc 2 is not ready for prime time.
Good Luck
Swiss_Cheese
Postato : 19/12/2021 7:38 pm
