Strange infill method, how to avoid this?
[Resuelto] Strange infill method, how to avoid this?
Olaf
 Olaf
(@olaf-2)
Why does PrusaSlicer at Layer 9 not make an complete infill? It leaves a lot of free space around the corners. But I want it to fill everything up to the holes in the object. In the next layer it will make a complete fill and close the holes, as it should be. I checked the object and tried to optimize the thickness of the holes, but it did not help. Is there maybe an option for this, that I have missed?
Best Answer by R&D:
@olaf-2
if you observe your project in feature mode, you may notice that Slicer is applying a bridging layer to span the void one layer below those areas. this is necessary, and a normal part of slicing. In fact a portion of your model requires support that you have not applied.
Respondido : 22/01/2023 10:57 pm
RE: Strange infill method, how to avoid this?
As usual, the way to get help grounded in data not just hunches is to upload a zip-compressed 3mf project file, so we can see ALL your settings as well as the model. From pictures alone, who knows.
Respondido : 23/01/2023 12:00 am
Olaf
 Olaf
(@olaf-2)
I tried this but the forum systems says that it is not allowed to add 3mf file for security reasons. I have zipped it with 7zip. It does not make much sense to me but now I was able to add it:.test
Respondido : 23/01/2023 8:53 am
R&D
 R&D
(@rd)
@olaf-2
Esta publicación ha sido modificada el hace 3 years 3 veces por R&D
Respondido : 23/01/2023 9:13 am
1 les gusta
R&D
 R&D
(@rd)
I ran out of edit time, but you certainly could flip the one part, and avoid the problem all together.
Respondido : 23/01/2023 9:32 am
Olaf
 Olaf
(@olaf-2)
Thank you for the reply. It seems that I have a 0.01mm void in my model. I changed a couple of things in my model, and now the infill is complete. It seems you are right, my model had a problem, some kind of void, that I have missed maybe. Thank you for your help.
Respondido : 23/01/2023 9:36 am
Posted by: @olaf-2
Yeah, you're not alone. We've all been praying to the Great Jo for years to allow 3mf files to be uploaded to the forum, to no avail.
Respondido : 23/01/2023 12:57 pm
