Stop print to add magnets
orbitcoms
(@orbitcoms)
Hi
I have followed online tutorial to add a pause in print to add magnets.
The problem is that I don't know when it has paused when I am doing other work. The head then cools down and I get a line in my print when I resume.
Is there a way to add a BEEP at the point the printer pauses to notify me? (I am using Mk3 s+)
Thanks
Napsal : 28/10/2022 11:39 pm
The M300 gcode generates a beep and you can include it with the 'Add custom g-code' option in the same menu as the pause.
Or:
Instead of a pause insert a filament change which will beep, add the magnets then reload the same filament.
Napsal : 29/10/2022 1:48 am
1 lidem se líbí
R&D
 R&D
(@rd)
Use something like, G1 X10.000 Y200.000 Z25 E0;M1;M105; In the custom layer G-code and forsake all other suggestions. obviously change the height (Z) to match the height of your particular Models Height.
It looks like this.
And here is an example of how the G-code can be used.
Insert_Part_G-code Example_R&D.Zip
Hint: Slice the file to view the custom inserted G-code
If this is beyond your current skill level, then move on and endeavor to educated yourself.
This post was modified před 4 years 2 times by R&D
Napsal : 29/10/2022 7:58 am
