Stop Print at set height
sean.t
(@sean-t)
Hi.  This is my first time using Prusa Slicer.  I've always used Simplify3D.
In S3D you can tell it to stop printing at a certain height.
Can you do this in Prusa Slicer without having to cut the object?  I can't find anything in the settings.
Thanks
Napsal : 05/03/2023 4:39 pm
RE: Stop Print at set height
In the slicer preview, right click on the vertical slicer at the appropriate height and insert a pause.
Okay, read your question again. Looks like you want to terminate your print, not just pause it. In that case the cut tool is indeed your best friend.
Napsal : 06/03/2023 2:05 pm
1 lidem se líbí
esmerel
(@esmerel)
Thanks, I didn't know that existed - never needed it before today! Solved a problem for me!
Napsal : 23/06/2023 1:49 am
