STL file with a cone-shaped interal roof appears with flat roof in PrusaSliver
iboates
(@iboates)
I have modified a 3D model in Blender to be hollow and have a cone-shaped roof so that it should be able to be printed without supports. I have exported to to STL.
However, when I load the file into PrusaSlicer, it interprets it as having a totally flat roof, which will certainly be impossible to print without supports.
Can someone explain to me what is going on? I have attached the .STL file:
Queen_hollow_1p0
Posted : 04/06/2022 11:33 am
RE: STL file with a cone-shaped interal roof appears with flat roof in PrusaSliver
There's plenty of errors in that STL, most of which Prusaslicer couldn't fix:
Having said that, it should be trivial for a Mk3S to bridge that roof, flat or not. I'd be more concerned about the sharp overhang at the top of the torso, where the head begins.
Posted : 04/06/2022 12:52 pm
iboates
(@iboates)
Thanks for the insight. The overhang around the torso actually prints just fine, I know because I already printed it up to the head where the cone roof begins (I was using a different, dome-type internal roof which collapsed.
Posted : 04/06/2022 1:37 pm
Is this Any Use?
Queen_hollow_1p0 (2)
If it is, you probably need to add a brim.
What was the original model like?
Could you have loaded the solid model into Prusa Slicer, and selected 0 bottom layers and 0%infill
with maybe 3 perimeters? probably need a brim! because there is negligible surface contact on the bottom
Joan
Posted : 04/06/2022 2:29 pm
iboates
(@iboates)
Thanks for the fix, how did you do it?
Posted : 05/06/2022 4:07 pm
I used Netfabb in Windows edition of Prusa Slicer, then I used Variable Layer height to reduce the layer height on the Shallow slopes.
Posted : 05/06/2022 9:32 pm
