stl file not visible on plater
RandyHoll
(@randyholl)
I am trying to load a topographic map stl file (see https://jthatch.com/Terrain2STL/ )  into Prusa Slicer 2.71, for the Sovol SVo4 printer, dual mode. After loading the file, the plater does not display the object.  The object can be sliced successfully, but I need to use the color paint capability of the Prusa slicer. I am able to successfully load the file into Cura and Slic3r with no issues. I also tried changing the printer to a Sovol SV04. single mode and to the Sovol SV06, but the object was still not displayed on the plater. Any suggestion on how to make the object visible is appreciated.
Best Answer by _KaszpiR_:
bottom left corner has two icons, one is for object and another is for sliced objects. If you import model while sliced object view is enabled then prior slice you cannot see anything 🙂
Napsal : 14/01/2024 7:53 am
_KaszpiR_
(@_kaszpir_)
RE: stl file not visible on plater
Napsal : 14/01/2024 1:23 pm
RandyHoll
(@randyholl)
Thanks, that was the issue. I should have obviously  read the manual a bit more thoroughly  🙂
Napsal : 14/01/2024 8:51 pm
