STL exports from FreeCad 0.21.2 are exploded when imported into PrusaSlicer
I have a part that I have designed in FreeCad that includes multiple objects. When I select all of the objects and export the part from FreeCad 0.19 to an STL file, then import the STL file into PrusaSlicer 2.7.1, the part appears normally, as below.
If I do the same export from FreeCad 0.21.2 to STL, upon import into PrusaSlicer 2.7.1, the part's objects appear exploded, as below.
Has something changed from FreeCad 0.19 to 0.21.2 in the way a part with multiple objects is exported to STL? Any help would be appreciated.
Publié : 05/02/2024 5:43 pm
