STL and OBJ export changes part size?
Apologies if already addressed somewhere, but I searched and could not find an answer. I'm taking a part from a build and exporting as STL or OBJ and I've tried either deleting everything off the field and importing it right back into the same exact setup or starting a new blank project and importing it and it comes out just a bit smaller in both instances. Very frustrating. I'm not an imperialist, so it's not that issue (I've seen that addressed here). See pictures with measurements - larger is original. Smaller is after reimporting the STL of the object.
Opublikowany : 05/08/2023 3:33 pm
