Still missing 3DLabPrint type internal surfaces using Even/Odd slicing mode
Jackheli
(@jackheli)
So slicing my plane with the Prusaslicer did not work. There are still internal walls missing even using the Even/Odd setting. Very disappointing. This does not happen with Simplify3D or Cura.
On consultation with Prusa they actually advised me to use Cura!
The plane can be found here:
https://www.rcgroups.com/forums/showthread.php?4033079-The-Gaplan-Edge-540-First-truly-3D-capable-3D-printed-plane
Attached is the project file
Ce sujet a été modifié il y a 4 years 3 fois par Jackheli
Publié : 28/02/2022 1:55 am
Jackheli
(@jackheli)
RE: Still missing 3DLabPrint type internal surfaces using Even/Odd slicing mode
Prusa followed up on the issue and gave me the solution! Amazing!
Change the "Slice gap closing radius" under Print settings - Advance to 0.001 mm
Back in business.
Publié : 28/02/2022 3:41 am
