Still canìt make it work with Duet 2 WiFi
Good morning, I can't make PS work with my Duet 2 WiFi...I've installed the latest version. The problem is that a very very few filament goes form the nozzle, I've tried to check and uncheck "Use relative E distance" but nothing works...here's my settings:
Did you see this https://help.prusa3d.com/en/article/sending-files-to-octoprint-duet_1663/
c'mon this has nothing to do with my question... please!
Go back to basics. Have you calibrated your extruders esteps ? When you get it up to temp via the printers menu and you tell it to extrude 100mm of filament does it actually extrude 100mm ? If your printers eeprom calibration settings are not correct then nothing a slicer tells it will be correct.
Confirm the basic operation from the printers menu without anything else first. Same with x/y/z.
RE: Still canìt make it work with Duet 2 WiFi
Probably your extruder estep values are not set correctly:
https://mattshub.com/blogs/blog/extruder-calibration
or
wbr,
Karl
work slowly
I agree with both Karl and Neo. I would work through the steps slowly and make sure you get it right. Like in carpentry, measure twice and cut once.
or
wbr,
Karl
steps/mm
Thanks but "unfortunately" steps/mm are perfectly setted, with Ideamaker or Simplify3D I have no issue and it all work perfectly...and in that slicer (as well as in PS) I have no overrides on step/mm....
or
wbr,
Karl
RE: steps/mm
Thanks but "unfortunately" steps/mm are perfectly setted, with Ideamaker or Simplify3D I have no issue and it all work perfectly...and in that slicers (as well as in PS) I have no overrides on step/mm....
or
wbr,
Karl
Ok if you are sure your new board is configured correctly for your hardware then please create a Prusa slicer project. Doesn’t matter what of, just a calibration cube will be sufficient. Then save the 3mf file, zip it up and attach it here. Must be zipped for the forum to accept the file.
with a project 3mf file we get all your settings, not just a few from a screen cap. It’s a snapshot of your environment. We can also slice and look at any gcode. Basically it’s the most efficient way to debug things currently.
wrong thread
Sorry, there was another thread re. Duet, took me a while to find the reference and posted to wrong thread.
