start gcode for CreatBot DX Plus
Sebastian Evridge Pope
(@sebastian-evridge-pope)
Hello! I started printing not too long ago using the CreatBot DX Plus which uses its own slicer (CreatWare) that is based on Slic3r just like PrusaSlicer. I decided I would prefer to use PrusaSlicer because there is a number of features which the native slicer did not have, but that is besides the point. I could not find a profile for printer in the PrusaSlicer configuration, so I just started copying all of the settings from my old slicer, including its custom gcode: however, the slicing always fails due to invalid custom gcode:
start_gcode
Parsing error at line 8: Not a variable name
{if extruder_id_0}
Here is the start gcode I use for reference:
G28 X0 Y0                ;move X/Y to min endstops
G28 Z0                   ;move Z to min endstops
;Add Clear Nozzle
G92 E0                   ;zero the extruded length
M83                      ;set E value is relative
G0 F4200 X0 Y0
{if extruder_id_0}
T0 F400                  ;activate extruder NO.0
G0 X10 Y0 Z0.4           ;move a bit while down the Z
M221 T0 S200             ;set flow is 200%
G1 F200 X30 E+8          ;extrude amont filament to clean the hotend
M221 T0 S100             ;reset flow is 100%
{if initial_extruder_id != 0}G1 F1000 Z1 E-2{endif}{endif}
{if extruder_id_1}
T1 F400                  ;activate extruder NO.1
G0 X40 Y0 Z0.4           ;move a bit while down the Z
M221 T1 S200             ;set flow is 200%
G1 F200 X60 E+8          ;extrude amont filament to clean the hotend
M221 T1 S100             ;reset flow is 100%
{if initial_extruder_id != 1}G1 F1000 Z1 E-2{endif}{endif}
{if extruder_id_2}
T2 F400                  ;activate extruder NO.2
G0 X70 Y0 Z0.4           ;move a bit while down the Z
M221 T2 S200             ;set flow is 200%
G1 F200 X90 E+8          ;extrude amont filament to clean the hotend
M221 T2 S100             ;reset flow is 100%
{if initial_extruder_id != 2}G1 F1000 Z1 E-2{endif}{endif}
M82                      ;set E value is absolute
G92 E0                   ;zero the extruded length again
;Add End
G0 Z15.0 F4200           ;move the platform down 15mm
;Put printing message on LCD screen
M117 Printing...
I have seen that there is a list of placeholders available for custom gcode, but I can't tell what they correlate to or which I should replace the invalid variable name with. Has anyone else dealt with this issue before?
Opublikowany : 26/06/2023 11:08 pm
andrewyww
(@andrewyww)
RE: start gcode for CreatBot DX Plus
Hey Sebastian,
Running into this issue myself. Have you found a fix since the time of your post?
Opublikowany : 21/07/2023 5:46 pm
1 ludzie polubili
Morgan Bengtsson
(@morgan-bengtsson)
Added a D600 to try PrusaSlicer, and moved config files over from CreatWare folder which let me pick the printer in the wizard but I got the same issue as you did.
Found that the PrusaSliser doesn't like the code about multiple extruders.
I updated the code to this which resolved the error, will try to print today and see what happens.
;Add Clear Nozzle
G0 F4200 X0 Y0
;Add End
M117 Printing...
Posted by: @sebastian-evridge-pope
start_gcode
{if extruder_id_0}
;Add Clear Nozzle
G0 F4200 X0 Y0
{if extruder_id_0}
{if extruder_id_1}
{if extruder_id_2}
;Add End
M117 Printing...
Opublikowany : 04/09/2023 6:37 am
Itamar foguel
(@itamar-foguel)
i was banging my head just about the same thing.
got the d600 pro here in my lab. so i consulted with a friend and he provided a solution by deleting all the if extruder id parts.
try using this start g code, or adjust it in the same manner to your printer specs:
G28 X0 Y0 ;move X/Y to min endstopsG28 Z0 ;move Z to min endstops
;Add Clear NozzleG92 E0 ;zero the extruded lengthM83 ;set E value is relative G0 F4200 X0 Y0 T0 F400 ;activate extruder NO.0 G0 X10 Y0 Z0.4 ;move a bit while down the Z M221 T0 S200 ;set flow is 200% G1 F200 X30 E+8 ;extrude amont filament to clean the hotend M221 T0 S100 ;reset flow is 100%
;Add EndG0 Z15.0 F4200 ;move the platform down 15mm;Put printing message on LCD screenM117 Printing...
This post was modified 3 years temu by Itamar foguel
Opublikowany : 04/09/2023 9:11 am
1 ludzie polubili
Marco Balestrini
(@marco-balestrini)
RISPONDI: start gcode for CreatBot DX Plus
start_gcode
{if extruder_id_0}
;Add Clear Nozzle
G0 F4200 X0 Y0
{if extruder_id_0}
{if extruder_id_1}
{if extruder_id_2}
;Add End
M117 Printing...
Try with this and let me know
; Add Clear Nozzle
G0 F4200 X0 Y0
(if extruder_id_0)
G1 F200 X30 E+8          ;extrude amount filament to clean the hotend
(if initial_extruder_id != 0) G1 F1000 Z1 E-2 (endif) (endif)
(if extruder_id_1)
G1 F200 X60 E+8          ;extrude amount filament to clean the hotend
(if initial_extruder_id != 1) G1 F1000 Z1 E-2 (endif) (endif)
(if extruder_id_2)
G1 F200 X90 E+8          ;extrude amount filament to clean the hotend
(if initial_extruder_id != 2) G1 F1000 Z1 E-2 (endif) (endif)
; Add End
; Put printing message on LCD screen
M117 Printing...
Opublikowany : 14/01/2024 7:19 pm
Naam
 Naam
(@naam)
This did not work for me. I don't think the Prusa Slicer does support conditional on which extruder is present. This is a custom variable in CreatBot's Slic3r fork. I'm not sure what's the best way to go from there. Are there any pointers you guys might have?
Thanks!
Opublikowany : 29/02/2024 3:57 am
Naam
 Naam
(@naam)
It does not look like I can edit my previous post, but I've confirmed that the variable in the Gcode above is not in the available placeholder of Prusa slicer:
https://help.prusa3d.com/article/list-of-placeholders_205643
Opublikowany : 29/02/2024 8:33 pm
work n hard not hardly workin
(@work-n-hard-not-hardly-workin)
I have a Creatbot D600 Pro 2 that I moved to Prusaslicer. Here is my working code. I have nozzle 2 priming before the main nozzle so that there is no oozing.
G28 ; Home all axes
G92 E0 ; Zero the extruded length
M83 ; Set E value to relative
; Start mesh bed leveling
G29 ; Perform mesh bed leveling
{if is_extruder_used[1]}
T1 ; Select tool 1 (E2)
G0 X50 Y5 Z[first_layer_height] ; Move to cleaning position
M104 S[first_layer_temperature_1] ; Set nozzle temperature based on filament type
M109 S[first_layer_temperature_1] ; Wait for Tool 1 (E2) nozzle to heat up
M221 S200 ; Set flow rate to 200%
G1 X0 E8 F200 ; Extrude filament to clean nozzle
M221 S100 ; Reset flow rate to 100%
; Set nozzle 1 (E2) to idle temperature after cleaning
M104 S[idle_temperature_1] ; Set nozzle to idle temperature after cleaning
M109 S[idle_temperature_1] ; Wait for nozzle to cool down to idle temperature
{endif}
; Clean nozzle routine for Tool 0 (E1)
{if is_extruder_used[0]}
T0 ; Select tool 0 (E1)
G0 X55 Y5 Z[first_layer_height]. ; Move to cleaning position
M104 S[first_layer_temperature_0] ; Set nozzle temperature based on filament type
M109 S[first_layer_temperature_0] ; Wait for Tool 0 (E1) nozzle to heat up
G1 X5 E8 F200 ; Extrude filament to clean nozzle
M221 S100 ; Reset flow rate to 125%
{endif}
M82 ; Set E value to absolute
G92 E0 ; Zero the extruded length again
; End G-code
M117 Printing... ; Display printing message on LCD screen
Here is my tool-change code too 🙂
; Tool change G-code script
{if next_extruder==0} ; Check if the new tool is Tool 0
{if layer_num<2}
T1; Select tool 1  (E2)
M104 S[idle_temperature_1] ; Set nozzle 2 to idle temperature
; Tool change to Tool 0 (E1)
; Move Z axis up by 1mm and move to a safe spot
G0 Z{layer_z+2} ; Move Z axis up by 1mm relative to current layer height
G0 X260 Y175 ; Move to x & y positions of wipe object (adjust coordinates as needed)
M104 S[temperature_0] ; Set nozzle temperature based on filament type
M109 S[temperature_0] ; Wait for Tool 1 (E2) nozzle to heat up
G1 E2 F200 ; Extrude filament to clean nozzle
{endif}
{if layer_num>=2}
G1 E8 F200 ; Extrude filament to clean nozzle
{endif}
{endif}
{if next_extruder==1} ; Check if the new tool is Tool 1
{if layer_num<2}
T0; Select tool 0  (E1)
M104 S[idle_temperature_0] ; Set nozzle 1 to idle temperature
; Tool change to Tool 1 (E2)
G0 X282 Y175 ; Move to x & y positions of wipe object (adjust coordinates as needed)
; Clean nozzle routine for Tool 1 (E2)
{endif}
{if layer_num>=2}
M104 S[idle_temperature_0] ; Set nozzle 2 to idle temperature
M104 S[temperature_1] ; Set nozzle temperature based on filament type
M109 S[temperature_1] ; Wait for Tool 1 (E2) nozzle to heat up
{endif}
{endif}
; End of tool change G-code script
This post was modified 2 years temu by work n hard not hardly workin
Opublikowany : 15/07/2024 3:22 pm
2 ludzie polubili
Mitja K
(@mitja-k)
Posted by: @lillian-wilson
G28 ; Home all axes
{endif}
{endif}
; End G-code
{if layer_num<2}
{endif}
{if layer_num>=2}
{endif}
{endif}
{if layer_num<2}
{endif}
{if layer_num>=2}
{endif}
{endif}
Hi, this G-code works great!
I'm having a lot of trouble operating D600 pro 2... Would you be willing to share some profiles, possibly for ABS?
I also believe that Z active compensation is not working at all, so a lot of clogging occure because sometimes it is too close to the bed, on other side it is too far and poor adhesion happens.
Any advice would be appreciated greatly. Thanks.
Best regards, Mitja
Opublikowany : 21/11/2024 9:12 am
anto
 anto
(@anto)
Hi Mitja K,
I encounter the same problem as you. Sometimes it is too close to the bed and on other side it is too far. I would like too know if you found the problem.
Best regards,
code works great!
Best regards, Mitja
Opublikowany : 23/01/2025 4:17 pm
Haaaaa so I haven't been able to work on the Creatbot in a while 😅 (Seasonal worker), and a lot of problems occurred while I was absent BUT! I will be updating in maybe two weeks as I will have actual training for it soon!
I wont leave people Hanging!
This post was modified 11 months temu by work n hard not hardly workin
Opublikowany : 04/06/2025 6:15 pm
