Stand alone installer
garethsnaim
(@garethsnaim)
Hi, when I used this installer it installs ok then soon after tells me there is an update which I duely downloads, it then opens to 'modify, repair, uninstall' options.
None of these are update or upgrade so the closest is modify, so I click that,  it then installs but then says error with installer.
And that's that. Does it every time.
OK bye.
Publié : 04/01/2022 2:19 pm
micha
(@micha)
RE: Stand alone installer
Are you sure you're using the correct version? (32 vs. 64 bit)
Can you tell a bit about your OS and versions?
Publié : 04/01/2022 3:00 pm
