Speed settings as it relates to the LCD panel
tentaclejoe
(@tentaclejoe)
Utenti
When adjusting the speed of a print on the LCD panel, how does that relate to the speed set in the slicer? For instance, if my perimeter speed is set to 50 in the slicer and I slow the speed down to 70% on the LCD panel, is the initial speed setting now 35 (70% of 50)  or is it 70% of 100? Hopefully my question makes sense 🙂
Postato : 03/01/2022 1:36 am
Swiss_Cheese
(@swiss_cheese)
RE: Speed settings as it relates to the LCD panel
@tentaclejoe
That's the first and only question I ever posted here, the answer was so good it made me want to stay and help.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/changing-print-speed-via-lcd-display-how-can-i-do-it-in-slic3rpe/
I hope this helps, thank bob if so.
Regards
Swiss_Cheese
The Filament Whisperer
Postato : 03/01/2022 1:49 am
1 persone hanno apprezzato
tentaclejoe
(@tentaclejoe)
Utenti
Excellent, thank you!  That helps a lot. That Bob is one hell of a guy. I've learned so much from his posts and website.
So in theory since I am using Bob's start G-Code I can just set the speed reset in the g-code to m220 s70 for this particular preset?
Postato : 03/01/2022 2:32 am
