Specify wall thickness in mm instead of lines?
Is it possible to specify how thick you want your perimeter walls to be rather than a line count?
Napsal : 20/11/2019 10:44 am
RE: Specify wall thickness in mm instead of lines?
Cura will let you do this. You'd have to do some calculation in PrusaSlicer to achieve the same effect as it's really meant to specify perimeter counts.
Napsal : 20/11/2019 10:46 am
