Some object are too tall and cannot be printed message.....
marcottt
(@marcottt)
Hi all, i'm trying to print 4 part substantially   but i get message every time some object are too tall.
Where i can manage this parameters? because i tried also only print 2 part (i'm sure i can)  but get always same message, the printer is a delta anycubic, when i setup prusaslicer i did not add the measure.
If i change extruder clearance in any way (tried 400mm to 0 mm no change) same reasult.
Attach the 3mf file.
thanks
Attachment removed
Best Answer by marcottt:
[SOLVED]
i read wrong about height.... ig a set 5mm of radius and 50mm of height it work....  (for example... now i search about real value).
Napsal : 29/04/2020 4:27 pm
RE: Some object are too tall and cannot be printed message.....
Under printer settings you can define the bed size and height
Napsal : 29/04/2020 5:03 pm
ok, now Im back on a pc and can download your project i see your issue.  Its because you are printing individual objects one at a time.  Slicer prints them in the order they are in from the tree list on the right.  With a normal cartesian bed the algorithm is for printing front of the bed to back so avoid the x axis rods.
theres a few issues on github related to this and they will be the first to say that the individual printing needs work.  I think it still prints front to back.  Dont know why your 1mm clearance wasnt behaving as expected but i changed it to a more reasonable 50mm and arranged things front to back and managed to get a configuration that it was happy with.  I think the clearance also works as a bounding box and doesnt take the actual shape into account.
Attachment removed
Napsal : 29/04/2020 5:41 pm
marcottt
(@marcottt)
yes i'm working on print one at time. Size of pieces is not a problem (i printed everithing with cura), but i cannot manage it... also with only 2 piece was unable to print.....
Napsal : 30/04/2020 8:31 am
marcottt
(@marcottt)
[SOLVED]
Napsal : 30/04/2020 9:52 am
