Small gaps in the two outside perimeters of the sliced file.
Fred Meijer
(@fred-meijer-2)
I am printing the Kickstarter Omni display cabinet. The 4 door corners 2+2 had some ugly spots on the outside. Two corners in the same spot as well as the other two corners at the same spot almost identical per set. When I checked the sliced file (very large zoomed in) it showed that the two outside perimeters were not connected and showed a little gap, like stopping and starting. Is this a mistake in the slicing function or can I change a setting in slicer software to avoid this?
Opublikowany : 04/12/2023 4:20 pm
