Slizer feature suggesttion for "Sequential printing"
ekholm
(@ekholm)
The extruder clearence should take into account the placement of the items to be printed.
If the items are placed one after the other then the height clearance is not relevant.
Also, it would be nice to change the order of how the items are printed
br
Posted : 15/01/2025 12:43 pm
RE: Slizer feature suggesttion for "Sequential printing"
Hi, welcome to the forum.  This is a user to user forum.  All feature suggestions and bug reports should be made at the relevant prusa github repository.  For Prusa Slicer that would be https://github.com/prusa3d/PrusaSlicer/issues
Before opening a new one though please please do a search for any relevant existing ones first. I can tell you though that this has been made before.
For example
https://github.com/prusa3d/PrusaSlicer/issues/13487 or
https://github.com/prusa3d/PrusaSlicer/issues/11834
https://github.com/prusa3d/PrusaSlicer/issues/11696
https://github.com/prusa3d/PrusaSlicer/issues/12846
https://github.com/prusa3d/PrusaSlicer/issues/7787
Anyway you get the point.  There are many, and many more closed as duplicates.
Even better this link has the ones with the correct tag on them https://github.com/prusa3d/PrusaSlicer/labels/sequential%20print   which will make it easier for you to look through the existing ones.  Go add your support to one of those.
Posted : 15/01/2025 4:38 pm
ssmith and ekholm liked
Brian
(@brian-12)
You can see the printing order in the slicer and reorganize your parts accordingly.
Height clearance is always relevant, whether to your print head or gantry.  It all depends on what you put for clearance values in the slicer.
I can almost guarantee you'll end up crashing into your parts at some point.  You'll also need to be cautious of first layers.  If you run a different first layer temp vs. the rest of the print you'll struggle with your sequential part first layers.  So I'd recommend only choosing a single temp.
Posted : 15/01/2025 6:18 pm
