Slicing not completing correctly
I’m having an issue where it looks good in preview but when sliced it gets all messed up
RE: Slicing not completing correctly
Im sorry those images are too small to tell what your issue is.
If you can you could save your project as a 3mf that will have all your used settings as well as the model, zip it up and post it here. That way we can have a look, try and duplicate the problem (once we know what you mean by messed up) and see if we can figure out why.
Does the red coloring not get your attention?
Your part has some issues that need to be fixed in your design software. I draw your attention to this info in the status box:
10 shells (if faces are not properly defined the slicer has no idea what to do); and 438 errors in the vertices. Fix these issues and it will probably slice better.
