Slicer STL Repair
RussG
(@russg)
Slicer STL Repair
I opened a FreeCAD STL file in Slicer 2.4.2 MacBook Pro running OS 11.6.7. Prusa Slicer indicated “Auto repaired 6 errors”. Does that mean my Prusa GCode export of the STL file should 3D print OK on the i3 MK3?
Also, I have come across some info suggesting that Prusa Slicer could be prompted to run repairs by clicking on the icon of a triangle with an exclamation point in it or selecting some menu option. Were these features related to n earlier version of the Slicer because I couldn't find the menu option and no combination of hovering over, clicking, right clicking command clicking etc. I tried did anything with the triangle icon, file name in the Expert tab of the software window or on the model itself seemed to bring up any repair options.
Best Answer by cwbullet:
This may help:  File>Repair STL File
Postato : 04/07/2022 7:39 pm
Utenti
RE: Slicer STL Repair
Postato : 04/07/2022 8:33 pm
jsw
 jsw
(@jsw)
It's very easy to produce wonky .stl files if you try, and even if you don't try.  😉
I've found some of the things that do it will be trying to edit objects that have chamfers/fillets without first undoing said ornamentation, or doing a boolean cut with an object that is not a true solid.
PrusaSlicer can repair some, not all, mesh errors transparently.  My experience is that if you slice it in PS and it produces a preview that looks sane, it will usually print as expected.
I've also found that Cura is, in many cases, more forgiving with wonky .stl files than is PS.
Postato : 04/07/2022 8:38 pm
1 persone hanno apprezzato
RussG
(@russg)
Yep. That's it, right there under my nose the whole time! I'm famous for missing things in plain site. Thanks.
Posted by: @cwbullet
Postato : 04/07/2022 10:32 pm
Utenti
Don't beat yourself up. It happens to all of us.
Posted by: @russg
Postato : 05/07/2022 12:08 am
SEIZMIC
(@seizmic)
How on earth does one narrow down where these errors might be? I've got 8. I'm just... going through feature by feature, but there are tons on this part. I think it *may* be due to these errors.
Postato : 23/05/2025 7:05 pm
