Slicer program window lags when moved
I don't know what the cause of this is but it used to work fine before I had to do a clean windows install. Now whenever I move the Slicer window it lags behind, making it very annoying to set it in the proper spot. I know I can disable showing window content under Windows performance, but that affects all programs so I can't use it.
Opublikowany : 22/07/2020 10:07 pm
RE: Slicer program window lags when moved
hi,
i am facing the same issue 🙁
Opublikowany : 24/07/2020 6:20 am
