Slicer oddities with embedded bodies
tishihtzu
(@tishihtzu)
I have been trying to embed some text bodies in solids without success.
Before moving to text, let's try this with just simple objects (see embedded square v1.3mf).
When I import this, assign extruders and slice, it comes out as expected:
Next, I created a square with text as bodies. When I import that and slice it, the slicer ignores the text bodies.
Why the different behavior?
Best Answer by Sembazuru:
While you are sorting out uploading (and getting around this forum's quirks), check the order of your parts in the object tree. This makes a difference. You should be able to drag and drop the parts in the object tree to change the order.
Veröffentlicht : 22/10/2024 10:51 pm
No file.  You need to zip a .3mf or the forum software rejects it.
Veröffentlicht : 23/10/2024 1:06 am
Sembazuru
(@sembazuru)
RE: Slicer oddities with embedded bodies
See my (limited) designs on:
Veröffentlicht : 23/10/2024 4:09 am
tishihtzu
(@tishihtzu)
Thank you, I tried (via the Choose File button) but it appeared only to let me attach one file and then the preview did not show any attachments either...
Veröffentlicht : 23/10/2024 12:02 pm
tishihtzu
(@tishihtzu)
Posted by: @sembazuru
Indeed that was the issue. Dragging the base part to the top of the list worked as expected:
Thank you for your patience.
--jon
Veröffentlicht : 23/10/2024 12:06 pm
