Slicer is segmenting print around thin element.
Hello, I would like to print this geometry where the connection is a thin wall element:
However, this is how the slicing is done:
Can I fix this in the Slicer software or do I need to do changes to the geometry? I have "Detect Thin Walls" ON.
Thank you for your help.
RE: Slicer is segmenting print around thin element.
you could try using a smaller nozzle, or
reducing the external perimeter extrusion width, from, 0.45mm to say 0.42mm, this may be enough to resolve your issue, and / or, you could increase your xy compensation value a little. which may also help
or you could save your slicer setup as a project file (,3mf file)
then zip compress the .3mf fil, and attach the resultant zip file to your next post, so that we can have a play with the actual files and make more educated suggestions
As Joan said, there are ways to try to make the slicer handle it but if you have control over the design I'd suggest you change the geometry of that thin bridge with the limitations of your printer in mind.
@andres-2
Out of curiosity have you tried turning detect thin walls off?
The Filament Whisperer
