Slicer in Inches Instead of MM?
Strona 1 / 2
Lane
 Lane
(@lane)
I don't see a way to tell Slicer that I want to work in inches instead of mm. Is there a way to do it?
Arlington, Wa, USA
Opublikowany : 27/04/2020 9:01 pm
RE: Slicer in Inches Instead of MM?
Not that I am aware of,
Scale your parts by 2540%
Opublikowany : 27/04/2020 9:42 pm
Lane
 Lane
(@lane)
@joantabb
Sorry but that won't work. I made them in a CAD program in inches.
I guess I'll learn to live with it if I can't change it.
Thanks for the reply
Arlington, Wa, USA
Opublikowany : 27/04/2020 9:57 pm
If your parts are created and exported in inches then when imported into Slicer they will be very small.  If you scale them larger In slicer using the scale option by 2540% like Joan said the parts will then be scaled correctly back to their original size.
However it should be easy in your Cad program to export in mm instead of inches even if you are working in inches.
Opublikowany : 27/04/2020 10:02 pm
Lane
 Lane
(@lane)
@neophyl
No, that has not been my experience at all. I've made about 3-4 parts in inches and printed them just fine. They do not scale.
Arlington, Wa, USA
Opublikowany : 27/04/2020 10:11 pm
If when imported into slicer they don't need rescaling then the parts have been exported in mm.
Its quite common to find stl files on thingiverse that have been exported in inches, we get 'Ive imported my part and its really small' questions often.  Its usually down to the mm/inches conversion and the fix to that is to scale up the small parts by 2540%.
Opublikowany : 28/04/2020 5:46 am
hansDaniel
(@hansdaniel)
Hi, if you need some good converter from inches to meter you can look here how-many-inches-are-in-a-meter
Opublikowany : 27/05/2021 6:04 pm
I am a yank also.  We need to learn metric.  I also used to design cad in inches but convert all my designs to mm.
Opublikowany : 27/05/2021 6:43 pm
Grok
 Grok
(@grok)
Put a check in the last box in the setup wizard "View Mode" section.
That may do the trick.
Opublikowany : 28/05/2021 6:05 pm
adesir
(@adesir)
Please think before posting, the link was simply an ad.
Mes modeles publics
Opublikowany : 28/05/2021 6:15 pm
OroNZ
(@oronz)
I'm wondering what I can do in Blender to preserve scale.
In Blender, I'm working in metrics - either in mm or m. When I export an STL from Blender and import it into PrusaSlicer I'm always given that "looks like saved in inches" dialog box.
(The dialog box isn't triggered by the object being metric or imperial - PrusaSlicer just thinks it's microscopic, and so it triggers this misleading dialog box.)
I say no, and scale up 1000%, which works... but is an erroneous workflow. Is there an import setting somewhere in PrusaSlicer that can correct for this problem?
Opublikowany : 04/07/2021 9:22 pm
Steve
(@steve-3)
I also design in inches. The last step before saving as STL is to scale X, Y, and Z by 2.54X. My original CAD files stay in inches.
It probably would be easier to design in metric, but all my tape measures and calipers are in inches.
Opublikowany : 04/07/2021 10:17 pm
Slicer now has the option to import in imperal units.
Opublikowany : 05/07/2021 12:17 am
1 ludzie polubili
Area51
(@area51)
Posted by: @oronz
In blender you can set your working scale to mm. Save the file in "File->Default->Save startup file". Next new file will automatically be set correct up for mm.
Opublikowany : 06/07/2021 11:54 pm
Sp4rkR4t
(@sp4rkr4t)
importing blender STL's issues
Posted by: @area51
I have the defaults in blender set to metric yet every time I'm importing into prusaslicer it brings up the dialog, and it's only prusaslicer that does this behaviour superslicer is fine with Blender generated STL's.
Opublikowany : 02/08/2021 9:55 pm
Area51
(@area51)
Setting up Blender for 3D precision modeling
@sp4rkr4t
I am still a beginner in Bender, but have no issues importing and exporting in metric (mm) when creating and editing models for PrusaSlicer.
Before I could use Blender for 3D modeling, I did a setup, following "Maker Tales" (YouTube) instruction for Learn Blender 2.9+ Through Precision Modeling.
Now Blender automatically start a new project/file with the correct setting for scaling.
Opublikowany : 03/08/2021 11:42 am
Sp4rkR4t
(@sp4rkr4t)
I know
My blender is fine as well, it's prusaslicer and only prusaslicer that brings up the maybe this is in inches dialog.
Opublikowany : 03/08/2021 11:48 am
Many of us using Blender and Prusa Slicer don't have any issue with scaling which does suggest that something in your Blender setup is not quite correct.  iirc as well as setting the units system to Metric you also need to set Unit Scale to 0.001 and then Length to Millimetres to actually get millimetres when modelling and exporting.
I think blend files are sort of self contained a bit like PS 3mf files so the settings are stored in the blender file.
Load the attached blend file of a 20mm cube and export it then load the stl into PS and see what you get.
Attachment removed
Opublikowany : 03/08/2021 11:58 am
Art Lieberman
(@art-lieberman)
Posted by: @diem
THANK YOU !!!!!   🙂
File | Import | Imperial Units
Opublikowany : 08/01/2022 9:03 pm
it-praktyk
(@it-praktyk)
I've checked that box by mistake and GUI changed to imperial.
Opublikowany : 16/01/2022 8:08 pm
Strona 1 / 2
