slicer errors on .07-.05 ultra but is not there on lower quality print
Devil_Dog76
(@devil_dog76)
If you find the lion STL since I could not attach this I found where the slicer generated errors in the upper part where the mane of the lion is at.  I tried to get the errors out and fix it, but this did not show up till it was done with a super high-quality print.  I am too new to be a seasoned slicer but thought maybe the errors where because it demanded too much quality.  I don't know if this is the real issue.  If a slice is done in ultra quality is this something that can come up or more of a model potential?
-Cody
Napsal : 28/12/2022 11:14 pm
RE: slicer errors on .07-.05 ultra but is not there on lower quality print
Almost none of that makes any sense.  Lion ? what lion, what settings exactly ?  Too many unknowns to even start.
As you are new to the forum here's the basics of getting help effectively.  Using Prusa Slicer get your project so its having the issue you want help with.  Then use File>Save Project As.  That will save a 3mf project file.
A project file is a snapshot, it contains everything you are slicing with, all 3 profiles you are using, the models, placement, any modifiers, supports etc.  With a 3mf anyone can slice with exactly the same settings you are using and can more easily debug any issues.  No playing 20 questions about settings.  Can be sliced and the preview stepped through to check for issues, if needed gcode can be generated etc.
Once you have the 3mf project file you have to ZIP it up into an archive.  Then attach it to a post here using the attach button.  It must be zipped or the forum just wont except it.  No warning, it just wont attach.  Its the same with stl files and most others too.  The forum is very limited on the types it allows you to attach.  A project is a million to,es better than a stl though as its the settings that are important.
Napsal : 28/12/2022 11:41 pm
