Slicer creates no infill in some parts
rebel0815
(@rebel0815)
Hello everybody,
I have a little problem with the PrusaSlicer...
When I slice an item, it doesn't create the infill on every place in the item.
When I try it in Cura or Z-Suite everything works well and it creates the infill everywhere.
PrusaSlicer does this even when I set Infill to 100%.
Has anybody a clue why this happens?
Kind regards,
Michael
Veröffentlicht : 11/01/2023 8:48 am
RE: Slicer creates no infill in some parts
Not from the information provided no.  We would need a copy of your Prusa Slicer project file attached to a post here.   Use File>Save Project As.  This will save a .3mf file.  A 3mf file contains a snapshot of your settings as well as the model etc.  it allows anyone to slice and get the same results.  We can then examine the previews etc closely and step through as well as all the settings.  We can also examine the model for potential issues too.  For example your image doesn't show if PS things there are model errors (yellow warning triangle).
One important thing to remember though is you MUST zip up the 3mf file for the forum to accept the file.  If you don't it will silently just not attach it.  You will think you have, but it wont be there.  SO please check its attached after posting as you only have a very few minutes to edit posts after making them.
Veröffentlicht : 11/01/2023 9:11 am
rebel0815
(@rebel0815)
Hello,
thank you for the reply.
Please find the file attached. Thank you very much in advance!
roundtest.3mf
Edit: seems it works. It's a sample file but with the same issue.
Kind regards,
Michael
Diese r Beitrag wurde geändert Vor 3 years von rebel0815
Veröffentlicht : 12/01/2023 8:23 am
good morning Michael.
i believe you are only getting infill where needed...
you need to be in Advanced Mode, or Expert Mode, to see the option!
if you uncheck this box, the issue should be resolved!
Veröffentlicht : 12/01/2023 10:21 am
rebel0815
(@rebel0815)
Hello Joan,
that's the solution!
Thank you very very much.
I really appreciate that!
Kind regards,
Michael
Veröffentlicht : 12/01/2023 12:05 pm
good news!,
we couldn't have seen that without the project file!
regards, Joan
Veröffentlicht : 12/01/2023 1:36 pm
