Slicer Connect to OctoPrint on HomeAssistant
Mat
 Mat
(@mat-7)
I run a Rpi for HomeAssistant and added Octoprint from the Supervisor>Add-on store. It works fine, connects to my Mini etc.
However when I try to connect Prusa Slicer to Octoprint using the IP address of the Rpi it does not connect, for example to access HomeAssistant I go to 192.168.1.50:8123, adding this in fails, tried with and without port (so port 80) also tried the network search but it fails.
I guess its more of the Add-on/HomeAssistant issue of how its exposing Octoprint to the network but just want to see if any one else has come across this.
Opublikowany : 20/10/2020 11:11 am
RE: Slicer Connect to OctoPrint on HomeAssistant
Posted by: @matgriffin
Hello and welcome to the Prusaforum!
Did you generate an API via Octoprint and register it in PrusaSlicer?
Opublikowany : 20/10/2020 11:57 am
Mat
 Mat
(@mat-7)
@karl-herbert
Hello.
Yes I added the API as well, but reading and viewing online videos it should find Octoprint before the API code is added in.
Opublikowany : 20/10/2020 12:00 pm
Gordon W
(@gordon-w)
Apologies if I'm misunderstanding what you have written but installing the HA addon doesn't install Octoprint, it just adds the ability for HA to monitor Octoprint and report on progress. Slicer needs to point to the IP address where you have installed Octoprint (The HA addon will also need to be pointed to that address.)
Opublikowany : 20/10/2020 1:00 pm
Mat
 Mat
(@mat-7)
@gordon-w
its full Octoprint in HA, its not a card that monitors Octoprint. Its really Octoprint in an iframe and an icon in the HA nav to get to itoctoprint in HA
This post was modified 5 years temu by Mat
Opublikowany : 20/10/2020 1:18 pm
Gordon W
(@gordon-w)
I'd never seen that addon before! I use the official Octoprint integration to break out sensors to monitor Octoprint. Have you tried entering port no 5000 (which Octoprint uses) rather than 8123 which HA uses?
Opublikowany : 20/10/2020 5:12 pm
1 ludzie polubili
Mat
 Mat
(@mat-7)
Posted by: @gordon-w
Thanks, found I had to set the 5000 port in the Add-on config
Now working.
Opublikowany : 20/10/2020 6:54 pm
1 ludzie polubili
bmorgenthaler
(@bmorgenthaler)
Posted by: @mat-7
I can't find this Add-on, only the Integration. Did you install a custom repository through HACS?
MINI+ with FW:4.3.3, Bondtech IFS Extruder, drilled out PC4-M8 couplers, 1 piece Capricorn bowden.
Opublikowany : 20/03/2021 2:40 am
