slicer 2.4.2. top_infill_extrusion_width error
Geoffrey
(@geoffrey-2)
Just upgraded to 2.4.2 (MacOS) and cannot print as it gives the following error:
top_infill_extrusion_width=0.3 mm is too low to be printable at a layer height 0.3 mm
Changing the layer height just generates the error again, with the new layer height.  Cannot find any reference to this parameter or anything which may be related. Anyone know what this is and how to fix it?
Thanks
Veröffentlicht : 26/07/2022 6:01 pm
RE: slicer 2.4.2. top_infill_extrusion_width error
Assuming you're using a 0.4mm nozzle, have you tried resetting Print Settings->Advanced->Extrusion width->Top solid infill to the 0.4mm used in the Prusa default print profiles?
Veröffentlicht : 26/07/2022 6:57 pm
Geoffrey
(@geoffrey-2)
Many thanks for directing me to the correct place and providing a solution.  The Top solid infill was set at 100% as with previous versions, but changing to 101% gets rid of the error.  I guess this is a bug.  By the way, the Default extrusion width is set at 0.45 (as before) even though the nozzle is 0.4.
Veröffentlicht : 26/07/2022 7:31 pm
