[Rozwiązany] Slicer 2.3.0 - Brim Question
StinkyPete
(@stinkypete)
I'm using Slicer 2.3.0, and for some reason the Check Box for a Brim is now selected as default when I open Slicer.    Is it possible to have this "unchecked" as the default?   It was before, but clearly something has changed.
Opublikowany : 16/07/2021 10:13 pm
t
Uncheck it, then save the profile as a custom profile. I suspect you have a custom profile and somehow accidentally checked the box. If you uncheck it and save the profile, it should overwrite the old one.
Opublikowany : 17/07/2021 1:01 am
StinkyPete
(@stinkypete)
Thanks fuchsr.   I knew that it had to be something simple, but I couldn't figure it out.  👍
Opublikowany : 17/07/2021 2:24 am
