Slicer 2.2.0 freezes when opening on a new windows 10 computer
JSCuda
(@jscuda)
Hi, I am wondering if anyone else is experiencing a problem with the latest version of slicer on a new windows 10 computer?  When I open it just freezes up and says not responding.  I installed it April 10th and it worked fine for a few days but now it will not.  I uninstalled it, re-downloaded the installer and installed it fresh but it still just freezes.  Any help would be appreciated.
Posted : 14/04/2020 7:36 pm
RE: Slicer 2.2.0 freezes when opening on a new windows 10 computer
Usually problems with graphics cards. Also unless you remove all the profile information it’s not a clean re-install as I don’t think that is removed when uninstalled.
‘if it used to work then it’s either a corrupted profile or an update with your software, usually as I mention the graphics card. Are you using a dual monitor setup by the way ? Also check for any Nahimic software that may be installed as part of audio/graphic setups.
Posted : 14/04/2020 8:21 pm
JSCuda
(@jscuda)
You nailed it neophyl, the Nahimic software that I installed caused the problem.  I uninstalled it and now slicer is working just fine again.  Thanks for your help!!!
Posted : 14/04/2020 8:47 pm
Also you might want to read https://github.com/prusa3d/PrusaSlicer/issues/2939 which is a raised issue that sounds identical to your issue, which is why I asked about dual monitor setups.
Posted : 14/04/2020 8:49 pm
