Slicer 2.0 configured for Ultimaker-S5
Soundbite
(@soundbite)
My personal printer is a Prusa i3 MK3 soon to be 3S. So I am familiar with Slicer 2.0 and prefer it to the Cura slicer that is used at work for an ultimaker-s5. I would like to setup a Slicer configuration for the work printer but I do not see an option for G-code flavor “griffin”. Is it possible to configure for the S5?
Opublikowany : 22/10/2019 7:21 pm
Nikolai
(@nikolai)
RE: Slicer 2.0 configured for Ultimaker-S5
Haven't seen any implementation of griffin or UltiGCode for Slic3r/PrusaSlicer. But maybe you can do similar (but limited) thing with RepRap flavor.
In general I would stick to Cura with Ultimaker printer. They are optimizing the slicer for their printer the same way PR is doing that with PrusaSlicer.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 22/10/2019 9:35 pm
alexandre.p
(@alexandre-pinto)
I'm kinda trying to do a similar thing as I need Slic3r command line to generate gcode for an ultimakerS3
If there is no "griffin" flavor , there is probably a way to make a script about converting for example a RepRap gcode into a griffin one
My problem is , I can't find what's differentiating griffin gcode from the other flavors, do you guys have any intel on this?
Opublikowany : 14/11/2019 3:32 pm
