Sliced object cut down to be flat and buggy
Riky35800
(@riky35800)
Hey! I want to do my post short and on the point so I have pictures
I have a shoe like formed object which I want to print hollow. I even painted the support to try to force the print
But it gets cut down somehow
90 degrees makes it.. I dunno what even is this
45:
- The model was made in Blender (Exported in STL)
- The problem isn't the models height. If I cut in half it makes these bugs too
- The most recent Prusa Slicer I could update (2.9.2)
Ultimaker Cura says "The highlighted areas indicate either missing or extraneous surfaces. Fix your model and open it again into Cura."
Prusa Slicer says "Try to repair the model or change its orientation on the bed"
Probably the model has the problem and there are some non 4 sided polys but I don't think that could be the problem since I printed even more messy cut models with edges everywhere. What causes this issue normally?
Thanks in advance,
Best regards
Best Answer by Diem:
Are you using 3D print toolbox within Blender?
Napsal : 28/06/2025 12:44 am
Napsal : 28/06/2025 5:50 pm
Riky35800
(@riky35800)
RE: Sliced object cut down to be flat and buggy
I didn't before, I checked it and it helped. Thanks a lot!
Napsal : 28/06/2025 9:40 pm
See those purple edges in PS ? Those are a visual indicator of model issues. I’d guess they were non manifold from the looks of things. The 3dPrint tool box in blender can analyse for you and show you were there are issues, it can even sometimes fix them for you depending on what the issues are. Even if it can’t then once you know where the problem is you can usually go in and manually fix things.
Napsal : 28/06/2025 11:47 pm
