Slic3r fills in all the corners
Víctor Ruiz
(@victor-ruiz)
Hello I´m desperate because I don´t know why sli3r fill the corners all the way up. I have tried almost everything but I don´t know what I´m doing wrong.
Thank you in advance!
Support
Napsal : 14/01/2023 11:17 am
RE: Slic3r fills in all the corners
First let me say thank you for providing a 3mf project file without being asked, thats such a nice change 🙂
This one is actually an easy one.  Under Print Settings>Infill>Advanced there is a expert level setting called Solid Infill threshold area.  Your profile has it set to 70 which is an old default that is common in many profiles.  The setting has been there since the Slic3r days before Prusa did their fork.
Any area less than the value gets filled with rectilinear solid infill.  Set it to zero and it turns that off.
Napsal : 14/01/2023 11:36 am
Víctor Ruiz
(@victor-ruiz)
Yes, that fixed the problem!
Thank you very much 😉
Napsal : 16/01/2023 8:59 am
