Skip one Layer / Layer shift
I am working on a project where I print filament on something. After 2 layers, one layer needs to be skipped or the nozzle has to be raised by 0.3 or 0.5mm to print the following layer.
{if layer_num == 2}
Layer shift
G1 Z0.5
{endif}
I expected a constant shift upwards, but actually the movement is not persistent.
My other option is to use a flow=0% command for one layer, but the would be unnecessary movements with possibly a clogged nozzle in the end.
Can someone explain a solution to me?
Thank you!
Veröffentlicht : 22/08/2024 2:45 pm
RE: Skip one Layer / Layer shift
Having this in the Layer Change section:
{if layer_num > 3}G1 Z{layer_z + 0.3}{endif}
Does not work and PS throws a parse error.
Veröffentlicht : 22/08/2024 3:09 pm
